How to connect to ESRI's versioned (e.g. QA version as opposed to default version) database using FME.
lsugumar
Best answer by trentatsafe
Hello @lsugumar,
You can access a specific version of your database by setting the version on the reader located here
You can also set the version on the writer:
This article may also help you: https://knowledge.safe.com/articles/30729/tutorial-extracting-differences-from-an-arcsde-geo.html
trentatsafe
  • September 8, 2017
Hello @lsugumar,
lsugumar
  • September 8, 2017
Hi @trentatsafe
Thank you! I was able to connect to the version I needed.
Lavanya.
