How to change the font size of text ,read from DGN File
  • Apr 3, 2022 8:35 AM UTC
  • 126 views
spiderman
Forum|alt.badge.img+7
i have used DGN Reader to read DGN File and it reads great but to modify the font size that read from this file , i use attribute creator and change the value in igds_text_size but i have no effect .
could someone fix my problem , why i got no effect of the font size ?
and is there other method that i could use to modify the Font size of text ?
parametersFME 2020
Thanks in advance
Best answer by itsmatt
How are you verifying the text size after setting it?
You can also look at the DGNStyler: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/dgnstyler.htm
It might be that you also need to set the fme_text_size attribute in addition to the igds_text_size
itsmatt
Forum|alt.badge.img+48
  • Apr 4, 2022 11:49 AM UTC
