How to change field length?
  • May 30, 2024 4:49 PM UTC
  • 429 views
vxn43
Forum|alt.badge.img+20
I have a text field (attribute) in a table that is 2048 characters in length. I want to change it to 50. What Transformer do I use in FME to achieve this? I am using FME Form 2021.
Best answer by andrewj74
you can set the schema/attributes in the writer to manual and then set the string length to 50. alternatively if you want to do it within the work flow you could use a schema setter transformer or similar to define it.
andrewj74
Forum|alt.badge.img+8
  • May 30, 2024 7:25 PM UTC
vxn43
  • May 30, 2024 7:38 PM UTC
SchemaSetter Transformer. That’s what I was looking for. Thank you.
