how to bypass filter on an esri feature service layer?
  • Mar 12, 2026 9:01 PM UTC
  • 132 views
tnarladni
Forum|alt.badge.img+24
there is a feature service layer (i’m the owner) with a filter statement on it.
when I view the layer’s properties on AGO, I can see the filter. When I add it to an arcpro project, I can see the filter in the definition query. Looking at the REST end point (the one that has the <organization>.maps.gis.com address), i see all records. When I add the layer into FME either by AGOL reader or feature Service reader, I only see the filtered records and I don’t know how to get all the records. AI is telling me to put 1=1 in the where statement to bypass, but it didnt.
donalmateer
Forum|alt.badge.img+13
Hi ​@tnarladni,
Thanks for posting! Before jumping into solutions, it would help to understand a bit more about what you're trying to achieve.
A couple of quick questions:
  • Do you actually need the definition query to stay on the layer, or is it something that was set up previously and you're not sure if it's still needed?
  • What are you trying to do with the data in FME, process all records, the filtered records only, or both?
From my understanding the reason why 1=1 does not work is that FME passes your WHERE clause as a parameter to the ArcGIS Feature Service Query API, but the server applies the definition query server-side first — so FME only ever sees the already-filtered result.
tnarladni
  • Apr 8, 2026 10:12 PM UTC
Hi ​@tnarladni,
Hi Donal. Thanks for looking at my question. Yes, I do need the definition query to stay on the layer. I need to process all the records and not just the filtered records.
donalmateer
Hi ​@tnarladni, thanks for the response!
Since the definition query needs to stay on the layer, the best approach might be to bypass the AGOL/Feature Service reader entirely and use the HTTPCaller transformer to query the REST endpoint directly, this way the server-side filter has no effect on what FME receives.
Here's the general setup:
  1. Add an HTTPCaller and point it at your feature service query endpoint.
  2. Generate a token to authenticate: Generate Token (ArcGIS REST API).
  3. Parse the JSON response back into features using a JSONFragmenter
More info on the HTTPCaller here: HTTPCaller Documentation.
Let us know if the suggestions help!
