how to break the JSON file into attributes?
  • Jun 3, 2020 6:02 PM UTC
  • 5 replies
  • 110 views
mr_fme
Forum|alt.badge.img+9
How can I broken the attached JSON file into attributes?
Thank´s
Best answer by steveatsafe
Hi @mr_fme,
Thanks for visiting LiveChat yesterday. Here's the workspace template I put together and also a small tweak to the sample data you provided as I added data for "risk" & "symptoms" to show the full workflow to get all attributes returned.
JSON_From_HttpCaller_Example.fmwt
erik_jan
Forum|alt.badge.img+26
  • Jun 3, 2020 7:16 PM UTC
Have a look at the JSONFlattener transformer.
That is built to take a JSON fragment and create attributes from it.
mr_fme
  • Jun 3, 2020 7:23 PM UTC
@erik_jan,
you are correct, but some attributes have values between square brackets and I cannot extract them correctly.
Look below:
erik_jan
  • Jun 3, 2020 9:29 PM UTC
@erik_jan,
Look below:
Those will become a list, that you can pick apart using the ListExploder transformer.
Hope this helps.
steveatsafe
Forum|alt.badge.img+16
  • Jun 4, 2020 8:15 PM UTC
Hi @mr_fme,
mr_fme
  • Jun 5, 2020 10:03 PM UTC
Hi @mr_fme,
Thank´s @steveatsafe.
I´m glad for your attention
