How reliable is MAPINFO_EFAL?
  • Nov 2, 2026 2:50 AM UTC
  • 34 views
nicholas
Forum|alt.badge.img+14
Hello all,
I am examining my options for writing MapInfo tables.
The documentation for the MAPINFO_EFAL Writer says that it is a Technical Preview and “Safe Software does not recommend using this format in production environments.”
So, I have been avoiding using this option.
But, it has been a technical preview for years now.
How reliable is it really? Am I being too cautious?
daveatsafe
Forum|alt.badge.img+24
  • Nov 2, 2026 9:02 PM UTC
Hi ​@nicholas,
The MAPINFO_EFAL reader/writer uses the Mapinfo Extended library to read/write standard Mapinfo TAB files. At present, there are a few issues that make the MAPINFO writer the better choice for writing to standard TAB files than MAPINFO_EFAL. You can also use the MAPINFO_EXTENDED reader/writer if you wish to read/write Mapinfo Extended TAB files.
nicholas
  • Nov 2, 2026 11:11 PM UTC
By MAPINFO Writer do you mean this one?
Precisely MapInfo TAB (MAPINFO/MITAB) Reader/Writer
daveatsafe
  • Nov 3, 2026 3:52 PM UTC
​@nicholas,
In a way - that doc actually covers two reader/writers: one uses the Precisely supplied Mapinfo library, which is Windows only, while the other uses the open-source cross-platform MITAB library. You can choose which reader/writer you want to use based on the OS you are running FME on.
