How do I convert an IFC file into an ArcGIS file?
  • Feb 22, 2021 12:56 PM UTC
  • 131 views
Should I use any transformers? Can someone help me with the exact inputs I have to give to the software to convert a Revit/IFC file into ArcGIS file
@vuppel_ce19539​ Have a look at the two webinar recordings on Extend the Value of Your BIM Data with FME Part 1 & Part 2. I think these will give you some ideas. The example workspaces are available for download.
