How could i show some data from different inspectors at the same view in FME inspector ?
  • Nov 9, 2022 8:58 PM UTC
  • 133 views
gogopotter90
Forum|alt.badge.img+14
i have different data and i would like to have all data in one view at FME inspector to show all of them together .
How could i achieve that ?
Thanks in advanced .
FME 2021
Best answer by andreaatsafe
Hi @gogopotter90​ ,
If you've already run your workspace with feature caching on, you can use the Ctl key and select the green magnifying glass on the transformers you want. This should then appear in the Visual Preview window.
Alternatively, you can connect Inspector transformers to the ports that have the data you are wanting view at the same time. Then run your workspace and the data should appear altogether.
-Andrea
andreaatsafe
Forum|alt.badge.img+17
  • Nov 10, 2022 12:13 AM UTC
Hi @gogopotter90​ ,
-Andrea
