How can i store _Packed attribute by AttributejSonPacker?
  • Sep 20, 2017 4:09 PM UTC
  • 5 replies
  • 73 views
How can i store _packed attributes which is having multiple attributes packed by AttributejSonPacker?
Can i store that _packed attribute as BLOB type attribute in File Geodatabase?
Thanks in advance.
Best answer by david_r
Here's a small workspace that demonstrates reading and writing JSON-packed attributes to a text attribute in a file geodatabase.
Disable either one of the bookmarks to test either reading or writing to the fgdb (don't leave both enabled).
attributejsonpacker.fmwt
  • Sep 20, 2017 4:15 PM UTC
Since JSON is text, the easiest is just to store it in a text attribute.
You can store a maximum of 2,147,483,647 characters in a text attribute in a File Geodatabase, which I guess should be more than enough.
  • Sep 20, 2017 4:57 PM UTC
Ok, and second part is i want to read that packed attributes in another workbench using AttributeJsonUnpacker followd by Filegeodatabase Reader.
How can i unpacked those attributes and use that as attr1, attr2, attr3 packed in _packed?
  • Sep 20, 2017 5:05 PM UTC
Getting the following error while storing it as text.
Python Exception <ValueError>: end is out of bounds
Error encountered while calling function `unpackAttributes'
f_21(PythonFactory): PythonFactory failed to process feature
  • Sep 21, 2017 7:14 AM UTC
That looks more like a Python error than a writer error. What are the values of attr1, attr2 and attr3?
  • Sep 21, 2017 7:17 AM UTC
