How can i set the character set for an Input CAT (txt) file.
  • May 20, 2013 1:26 PM UTC
  • 59 views
jan
Hi, How can i set the character set for an Input CAT (txt) file. It seems it is not possible and when writing to a database (UTF-8) the scandic characters get messed up. Shold FME be able to recognize the character set from the file?
fmelizard
Forum|alt.badge.img+22
  • May 20, 2013 1:35 PM UTC
I dont have much experience with the CAT reader, but, according to the documentation it does not seems to be possible....
sigtill
Forum|alt.badge.img+25
  • May 21, 2013 6:53 AM UTC
Hi!
After reading the file, can you then use a TextDecoder or TextEncoder to properly convert to UTF-8?
Another option woule be to use the Textfile reader instead of the CAT - reader, and specify the Character encoding. And afterwards one SubstringExtractor for each column to get. Does not work with Generic Readers - however if you always have the same formatted input-file it will work.
Also you can request safe to include the Character Encoding option on ALL NON-BINARY files READ and WRITE, not sure if that is already a PR.
