how can i read or write to smallworld PNI
  • Aug 11, 2017 9:40 AM UTC
  • 154 views
f.kemminje
Forum|alt.badge.img+11
I installed smallworld PNI(Physical network inventory)In the same machine also installed fme desktop 32 2017 with GE smallworld licensing 30 days eval license.also requested GE to provide *.dll and *.fmf files for fme(for GE smallworld reader and writer ), and placed in respective folders.I opened fme desktop and tried to add the smallworld reader , but fme saying “ unable to connect smallworld server, is it running?”now how to start smallworld server ? Do we need to start fme inside PNI ? if yes where should I go to start fme?I strucked somewhere. pls help me
erik_jan
Forum|alt.badge.img+26
  • Aug 11, 2017 6:07 PM UTC
We have done numerous project writing to SmallWorld PNI schema.
But we are always using the Spatialbiz plugin for SmallWorld in FME.
You can find information about the plugin on Spatialbiz plugin or via Support@Spatialbiz.com
rylanatsafe
Forum|alt.badge.img+14
 @fkemminje - After installing the GE Translators Suite / Module for Smallworld, there should be some instruction in the docs\ directory.
This article might help you out – to initiate the Smallworld VMDS for connections, you must invoke the command to start connections using the Smallworld "command prompt".
fme_connection_service.start(30000, _unset, :gis)
