How can I make FME writing to postgis (line) and not geometry type
  • Jun 13, 2014 12:25 AM UTC
  • 5 replies
  • 167 views
Hi
I'm trying to use FME to get shapefile to Postgres (postgis) but there is no option in the writer to choose point, or line, etc. .. What I get in postgis geom type geometry and not geom type point or lines, etc...
any help will be appreciated...
thanks
gio
Forum|alt.badge.img+15
  • Jun 13, 2014 10:55 AM UTC
PostGis:
GeometryType — Returns the type of the geometry as a string. Eg: 'LINESTRING', 'POLYGON', 'MULTIPOINT', etc.
Synopsis
text GeometryType(geometry geomA);
Description
http://postgis.net/docs/GeometryType.html
  • Jun 13, 2014 12:56 PM UTC
thanks.. what I mean it was possible at FME 2013 to find this linstring, polygon, etc. at the parameter of writer but in FME 2014 .. i can not fint them !!?
gio
  • Jun 13, 2014 1:40 PM UTC
in the fme 2013 version. (im still on 2013 sp2 and sp4)
 you can set the "Create Generic Geometry Column" option. Then only on type of geometry is allowed. You have to filter the geometry using fme to select only the type you want to wirte.
So if u set this option and only feed it polygons, GeometryType would be 'POLYGON'.
Is this option not available in fme2014 anymore?
  • Jun 13, 2014 2:26 PM UTC
There seems not to be such an option also in the PostGIS writer of FME 2014.
A table of PostGIS database can contain features having various geometry types simultaneously. If you have to avoid to write features other than lines, consider using the GeometryFilter before the writer, as Gio mentioned.
Takashi@Vancouver
  • Jun 14, 2014 2:20 AM UTC
Thanks Gio and Takashi for your answer...
