How can i get the pdf reader to read all of my pdf
  • Jun 6, 2019 3:41 PM UTC
  • 33 views
jurgenmack
Forum|alt.badge.img+9
PDF reader only reads a portion of the input fie. Source DPF below.
FME Reader result:
debbiatsafe
Forum|alt.badge.img+24
Hi @jurgenmack
Which version of FME are you using to read your PDF? I would recommend trying FME 2019 as a number of improvements have gone into the PDF reader in 2019.
For example, using the same reader parameters, FME will read the same PDF very differently depending on the version used (see screenshot below).
