How can I get smallword (SWORLDSWAF) reader writer plug in on my FME smallworld edition?
  • Dec 13, 2021 9:54 AM UTC
  • 204 views
jitsu87
I have FME Small world Edition license on my system but I am unable to read the data as it shows below error.
Please help me with this.
@jitsu87​ Make sure you have the correct version of the sworldswaf.dll that matches both your version of Smallworld and also the bit version (32 or 64 bit) of FME you have installed. More details on the Smallworld configuration here.
milo89
Forum|alt.badge.img+26
  • Dec 14, 2021 8:59 AM UTC
Probably worth mentioning the performance issues if you're using Smallworld 4.3 - While you're getting things from GE, they can provide a patch to resolve the problem.
More handy tips on common errors etc. can be found here. (You can ignore the 64bit incompatibility statement and refer to the Smallworld config article mentioned above.)
