How can I configure FME Server 2013 to use Exchange Server for Notifications?
How can I configure FME Server 2013 to use Exchange Server for notifications?  FME Server 2010 supported this and I can't seem to find any documentation on how to do so in FME Server 2013.
  • April 5, 2013
It is possible, using the SMTP transport protocol, as far as I know.
It may be necessary to do some configuration on the Exchange server to enable this, depending on your setup.
David
Forum|alt.badge.img+4
  • April 8, 2013
In 2010, you could configure the SMTP in the installation dialog or the webserver's properties.config file for the Data Download service.
In 2013, they're encapsulated this within the Web Admin interface under the Notifications tab I believe. Set up the SMTP settings for Exchange within the Subscription settings of the Notifications tab.
