How can I change the colors for a KML line when it is rolledover or selected?
  • Feb 18, 2016 5:19 PM UTC
  • 157 views
I have some route geometry that I am trying to highlight when it is selected or rolled over. I think that I should use the KML styler but I am not sure how to proceed.
erik_jan
Forum|alt.badge.img+26
  • Feb 18, 2016 5:29 PM UTC
From your (short) description I would think you need a some sort of test for selected routes (Tester or TestFilter) and attach different KMLStylers to the output ports of the test transfomer. That way you can style different selections in a different way.
Instead of the KMLStyler you could also use the FeatureColorSetter transformer if color is the only styling option you need.
  • Feb 18, 2016 8:41 PM UTC
It seems like the answer lies in something called style map?? OR.. in mapping a color to one of these exposed attributes. (see attached)feature-type-properties.png
mark2atsafe
Forum|alt.badge.img+59
Yes, style map. I have the info somewhere I'm sure. Let me see what I can find.
mark2atsafe
OK, a fairly quick process, and not really difficult. I created a demo for you.
The workspace and data are here: https://www.dropbox.com/s/g9z6c93yvpvtc3k/KMLHighl...
I recorded creating the workspace and the video is here: http://screencast.com/t/4pZr5wX0oL
There's also an article in our knowledgebase: https://knowledge.safe.com/articles/869/highlight...
To document the process:
1) You create a single feature and style it with the KMLStyler. You give it a kml_id attribute with a value like normal_style
2) You create a single feature and style it with the KMLStyler. You give it a kml_id attribute with a value like highlight_style
3) You write these to a feature type called Style
4) The data you want to style you give an attribute kml_target_style_normal (with a value of normal_style - i.e. what you set the style kml_id to). You also give it an attribute kml_target_style_highlight (with a value of highlight_style).
5) If your data has existing colors, expose and remove the FME attributes fme_color and fme_fill_color
6) Run the workspace! You'll find that your data has the normal style, but when you mouseover it, it will get the highlighted style
