How can I change a field that contains a data change to an ArcGIS Online compatible Datetime field?
  • Apr 2, 2021 3:49 PM UTC
  • 126 views
mapster
When trying to change the data type in the ArcGIS Online writer, the esriFieldTypeDate(width) is not an option. I want to have this type of field because I want to enable time in my hosted feature service.
debbiatsafe
Forum|alt.badge.img+24
Hi @mapster​
What version of FME are you using? Using FME 2021.0, I was able to select Date as a data type in the ArcGIS Online writer feature type. This data type should be available in older versions of FME as well.
AGOLDate
