Hi there! How can I connect Small World database?
  • Apr 3, 2019 3:36 PM UTC
  • 6 replies
  • 81 views
I want to create a plugin that will take some data from the small world and send it to another application. How can I get access to the small world database? What kind of problems can I face?
erik_jan
Forum|alt.badge.img+26
  • Apr 3, 2019 4:27 PM UTC
A plugin to read and write Smallworld data using FME is built by Spatial Business Systems.
Information can be found here: http://www.spatialbiz.com/spatialbiz-plug-in.html
Thanks a lot, I will get in touch with them. But is there any other way how to connect to the Smallworld Database?
Thank you in advance!
xiaomengatsafe
Forum|alt.badge.img+11
Hi @tsymbalruslan2, Like erik_jan suggested, the Smallworld plug-in by Spatial Business Systems is a great option to connect to Smallworld Database.
Here is an article with a lot of details on all connecting to Smallworld from FME: https://knowledge.safe.com/articles/107/fme-and-smallworld-configuration-options.html
It also included some other options. Hope this helps.
  • Apr 9, 2019 2:16 PM UTC
Here's a tutorial. There are a few ways to do this. We will be building something using smallwords translators suite to talk to FME and then across to ESRI SDE and back again.
https://knowledge.safe.com/articles/48300/tutorial-getting-started-with-the-smallworld-datab.html
Note that you will need the FME smallword edition, which I believe ships from GE.
Thank you very much!
