Hi there, Could I please have an update on if the I3S writer support point clouds after the release of 2023.1.1? If not then could I please have an update on the timeframe on this? Thanks, Shilpa
shilpak
Participant
Forum|alt.badge.img+3
edgarbaculi
Forum|alt.badge.img+4
  • December 14, 2023
@shilpak (Locus) Thank you for your question! At this time the work is ongoing and we will be assessing the work further in 2024. Currently there is not a clear timeframe of when an official version will provide support for point clouds in our I3S writer. For more context and help our Developers, we would appreciate details of your work that requires or would benefit from the I3S writer supporting point clouds. I can then share those details with our Developers and advocate on your behalf regarding the I3S writer.
swit012
Participant
  • Participant
  • February 16, 2024
@edgarbaculi , is there an “unofficial” way to create SLPK point clouds from las or other formats? The main reason we purchased FME Server some years ago was for the creation of point cloud SLPKs and there’s a growing sentiment in the business that FME is never going to make good on what was promised on your website about point cloud support.
edgarbaculi
  • February 16, 2024
 @swit012 Thank you for your question! We appreciate you purchasing FME Flow and your support. As mentioned work is ongoing and we will be assessing the work further in 2024.
In the meantime the following community response and article may offer some ideas and help you:
For more context and help for our Developers, we would appreciate details of your work that requires or would benefit from the I3S writer supporting point clouds. I can then share those details with our Developers and push/advocate on your behalf regarding the I3S writer. We thank you for sharing your needs!
geoloe
  • January 7, 2025
Hi, we would also be happy if I3S Writer would support Point Clouds.
Reason: Rendering of point clouds in ArcGis-Online for presentation purposes. - We use Airborne Laserscanning Data to plan new high-voltage lines and have to present the planning result to decision makers. The easiest & realistic way to represent vegetation (Trees,..) is via dense point clouds.
kailinatsafe
Forum|alt.badge.img+21
Hello ​@geoloe, we appreciate your interest on the issue, thanks for checking in! We are actively working on adding point cloud support to I3S (FMEENGINE-82595). I have made a note on FMEENGINE-82595 to update this thread when functionality becomes available! No timeline is available at this time. Sorry to be the bearer of bad news! Kailin.
