Hi! Is it possible to connect an Smallworld DB directly using FME as I can do with an Oracle DB?
  • Oct 8, 2019 4:25 PM UTC
  • 6 replies
  • 84 views
jalejandroruizc
Is it always necessary to have PNI or another Smallworld application running with FME?
erik_jan
Forum|alt.badge.img+26
  • Oct 8, 2019 4:46 PM UTC
There are two ways of reading/writing Smallworld data in FME:
FME has a Smallworld reader/writer that requires the Smallworld edition license.
A third party FME Smallworld plugin is available. See this link SBS Plugin for more information. This solution uses the FME database edition license.
Hope this helps.
jalejandroruizc
Thank You very much!
jalejandroruizc
We have FME 2018.1 with Smallworld Edition License. I will try to connect the DB.
Thank You.
milo89
  • Oct 9, 2019 1:01 AM UTC
It's definitely possible but you need to ensure that the Smallworld dll and metafile are available to FME before you can use the reader/writer.
I found this tutorial extremely useful when starting out: https://knowledge.safe.com/articles/48300/tutorial-getting-started-with-the-smallworld-datab.html
We're currently using Smallworld 4.3, there are training resources for this version available: https://knowledge.safe.com/articles/55589/fme-desktop-for-smallworld-training-course-resourc.html?
jalejandroruizc
Thank You very much!!
milo89
  • Oct 9, 2019 10:11 PM UTC
Also, I'm not sure of your configuration but we always need Smallworld to be running so that the magik script can open a port to FME.
