Hi I am getting error(" ORA-01002: fetch out of sequence") while converting oracle spatial to microstation dgn for a particular database table . Kindly let me know how to resolve it.
  • Apr 13, 2017 7:16 AM UTC
  • 147 views
erik_jan
Forum|alt.badge.img+26
  • Apr 13, 2017 2:31 PM UTC
The easiest way is to increase the number of records to fetch at a time.
The default is set to 200.
If you set that value to more than the number of records to fetch it should not give that error.
kumarkannan1980
Participant
Thanks for your reply. Is it possible to set the value through coding (c#.net), because I am extracting features using fme .net library . Kindly let me know.
erik_jan
  • Apr 14, 2017 5:48 PM UTC
I have no experience with c#.net coding, but it should be possible if you publish the parameter (right click the parameter and use "Create User Parameter").
kumarkannan1980
Participant
It is not working, still I am getting the error even I set the parameter as per your suggestion.
