When using the GUID generator i would like to assign that column as a primary key without opening the writer and assigning it? Is there a transformer i can use for this? (Would be a great addition to that transformer.)
GUID Generator assigning Primary key automatically
Best answer by david_r
The GUIDGenerator custom transformer is not needed, you can get the exact same result from a simple AttributeCreator and it allows you to specify the output attribute, e.g.
