GTFS-realtime reader
  • Mar 5, 2014 8:13 PM UTC
  • 166 views
philippeb
Forum|alt.badge.img+23
Hi community,
I have links (with token) here that give me the opportunity to have GTFS data into realtime. So I could have bus realtime position or alerts by exemple : https://developers.google.com/transit/gtfs-realtime/
Would you know a method to read this data into FME?
My goal would be to read this data and update the last position into ArcGIS via FME. If you would know a way to use the GTFS-realtime into ArcGIS, I would be interested too. Honestly I don't know what to to with those links...
thank you
Best answer by david_r
seems like the GTFS alerts is an ordinary webservice. In that case, I'd consider using the HTTPFetcher.
Another solution could be to use a Python script to access the GTFS data and pass this on as a feature to FME. The PythonCreator would be a good match for this. This would probably be my preferred solution for anything but for the most simple REST-based webservice.
David
  • Mar 6, 2014 9:19 AM UTC
David
