GML Writer
bayram
Forum|alt.badge.img+5
Hello, GML always writes a hyperlink at the beginning of the output, how can I fix this?
Best answer by crystalatsafe
Hi @bayram
Which version of fme are you using?
If you are able to, please send over your workspace with some sample data and I can have a closer look.
Crystal
crystalatsafe
Forum|alt.badge.img+19
  • June 20, 2024
Hi @bayram
Crystal
bayram
  • June 25, 2024
Hello crystalatsafe, I am sharing the DWG file I have with FME WB.
bayram
  • June 26, 2024
version 2024.0.1
crystalatsafe
Hi @bayram
Are you able to explain or identify where the unwanted hyperlink is? It is not clear at this time.
Are you talking about the gml header at the beginning of the citygml file (eg. seen in Notepad++ for example)? In a gml file, the header is used to define the XML schema and namespaces that the document will use.
Alternatively, are you talking about the 'CityGML' prefix on the citygml layers in the FZKViewer? If so, I think this is a fault of the application. If you use QGIS to view the model, the 'CityGML' prefix is not present.
If you can help identify the exact issue, we can look into this further.
Crystal
bayram
  • June 28, 2024
Merhaba crystalatsafeI have a serious lack of knowledge about the city gml hierarchy. If it is convenient for you, I would like to organize a meeting and discuss the data.
crystalatsafe
Hi @bayram
If you are looking to learn more about the City GML hierarchy you can review this documentation and tutorial:
Writing CityGML from FME
Tutorial: Getting Started with GML
If you still have questions, please feel free to submit a support case and our team can schedule a call.
