GML to PDF
  • August 6, 2019
  • 30 views
Hi all, i was wondering if it is possible to convert a gml file into a pdf? or convert the gml file into an image and place that image in a pdf? Thankyou
Best answer by sigtill
I would suggest using MapnikRasterizer to convert from Vector to Raster - there you can also set colors, styles etc per layer.
Depending if the GML-file is large or not you can also write directly to PDF as Vector and do the styling on the vector by using the PDFStyler and style each layer/feature_type different:
sigtill
Forum|alt.badge.img+24
  • August 7, 2019
