GML schema writer doesn't account for null values in dates
  • Jul 18, 2019 3:13 PM UTC
  • 63 views
tsirkuse
Forum|alt.badge.img+4
I am extracting data from a dB and writing it to a gml file with the GML writer.
I am also writing the xsd schema.
In my data, some dates are empty, and this is normal. However, in the XSD file writen by FME the dates are not nullable. The type of error I am getting is:
_xml_error{5}.desc (string): invalid date value ''
I am wondering if I am doing something wrong or if there is a problem with the xsd writter?
stalknecht
Forum|alt.badge.img+22
  • Jul 19, 2019 7:37 AM UTC
Is it Null or just an empty space?
Look in the XSD and change minOccurs="1" to minOccurs="0" for the date field.
tsirkuse
  • Jul 19, 2019 2:11 PM UTC
Thank you but there is no minOccurs in the xsd. I tried adding it but it didn't help.
<?xml version="1.0" encoding="UTF-8"?>
<schema xmlns:gml2="http://www.safe.com/gml2" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.safe.com/gml2" elementFormDefault="qualified">
<import namespace="http://www.opengis.net/gml" schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
<element name="FeatureCollection" type="gml2:FeatureCollectionType" substitutionGroup="gml:_FeatureCollection"/>
<element name="dates_test" type="gml2:dates_testType" substitutionGroup="gml:_Feature"/>
<complexType name="FeatureCollectionType">
<complexContent>
<extension base="gml:AbstractFeatureCollectionType">
</extension>
</complexContent>
</complexType>
<complexType name="dates_testType">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element name="ID" type="long"/>
<element name="START" type="date"/>
<element name="END" type="date" nillable="true" minOccurs="0"/>
<choice>
<element ref="gml:polygonProperty"/>
<element ref="gml:multiPolygonProperty"/>
</choice>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
stalknecht
  • Jul 20, 2019 9:22 AM UTC
<complexContent>
</extension>
</complexContent>
</complexType>
<complexContent>
<sequence>
<choice>
</choice>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
Can you try to post a FME template? The gml example in your post is readable how is it generated? Which writer do you use?
