GIS to DWG with attributed block
  • Aug 30, 2018 2:28 PM UTC
  • 27 views
alanaliberti
Is it possible, in a translation of GIS to DWG, to insert attributed blocks and fill in its fields?
fmelizard
Forum|alt.badge.img+22
  • Aug 31, 2018 9:24 PM UTC
Hi @alanaliberti. I attempted to give you a starting point in my reply to your comment on the article: https://knowledge.safe.com/articles/59335/autocad-dwg-block-attribute-extraction.html
I would suggest reviewing Give Your DWG Some Style: Using the DWGStyler, template files, blocks and more: https://knowledge.safe.com/articles/29869/working-with-the-dwgstyler.html. In the article, example four details how to use the DWGStyler transformer tool to create blocks (with a template file).
