Get a list of valid reader/writer formats in a workbench
  • Mar 9, 2020 4:33 AM UTC
  • 117 views
jstanger
Is there a way in a workbench to retrieve a list of all the valid formats that the version of FME currently running the workbench can use? A separate static file isn't really able to solve my issue. I know it is a strange request.
Essentially, we are using FME Server and will be using a Generic Reader to parse all user provided data then filter by a pre-configured list of valid formats my workbench will read from. The clients require the ability to add new formats and I'm trying to see if we can create a workbench that validates their configuration file against what FME can actually do.
Hi @jstanger, thank you for this question! We have a FORMAT reader internally that can generate a list of available reader/writer formats. I've reached out to my colleagues, and we put together a sample workspace where you could access this reader and further build on it. Please see attached fmw file and also the annotations for more details. We recommend using FORMAT_NAME attribute to identify the formats and first to filter by VISIBLE = YES for externally available formats only.
For your validations, do you check if the current FME has a license for these formats? Does this include downloadable or only shipped formats? Is there a need to differentiate if it's a reader or writer? There are a couple of attributes that you could test on as noted in the workspace, but feel free to let us know if you have further questions. Hope this helps!
FormatReader_SampleWorkspace.fmw
jstanger
  • Mar 13, 2020 10:48 PM UTC
Hi @alyssaatsafe, copying that reader between workbenches worked a treat. Just need to check there won't be any issues publishing to FME Server.
The config file I'm using is already referencing both FORMAT_NAME and FORMAT_NAME_LONG as well as an extension attribute to match against. I also have a writeable flag that I will be checking for licence status and will warn if it is currently unlicensed.
Since it appears that dynamically writing N files each with its format dynamically defined is a little beyond the FeatureWriter capacity right now I think it is safe enough to skip checking if the writer can be created.
