Georeferenced pdf to digitized layout map
  • Apr 14, 2026 10:10 AM UTC
  • 137 views
pradeephj3571
Forum|alt.badge.img+5
I have georefferenced pdf file(HLB_Map) and i need a output as digitalized layout map( for reference  i have attached ) by using raster pdf file...Please give a guidence
raghavendrans
Forum|alt.badge.img+28
​@pradeephj3571 From your email, are you looking to perform a raster to vector conversion using the data in your georeferenced pdf?
Happy FME :-) ing
SRG
pradeephj3571
  • Apr 14, 2026 12:10 PM UTC
Ya...Excatly
raghavendrans
​@pradeephj3571 Converting a georeferenced PDF to vector data in FME is doable, but there are a few key decisions that affect how clean your output will be!
  • RasterSelector → isolate bands if needed
  • RasterBandInterpreter → convert to grayscale if required
Clean the Raster
Garbage in = Garbage out.
Use:
  • RasterExpressionEvaluator → thresholding (e.g., isolate lines)
  • RasterConvolver → smoothing
  • RasterMosaicker (if tiled)
Convert to binary if needed (black/white) before vectorizing
Vectorization
Use one of:
Option 1: RasterToVectorCoercer
  • Best for:
    • Simple shapes
    • Boundaries
  • Outputs:
    • Polygons or lines
Option 2: RasterToPolygonCoercer
  • Good for:
    • Classified rasters
    • Land-use maps
Clean the Vector Output
After conversion:
  • Generalizer → simplify geometry
  • AreaFilter → remove noise/small polygons
  • TopologyBuilder → fix connectivity
  • LineMerger → join broken lines
Optional: Extract Labels (OCR)
If your PDF contains text labels:
  • Use:
    • RasterTextExtractor (OCR-based)
  • Or if vector PDF:
    • Text comes directly via PDF reader
Write Output
This is a quick overview.
Cheers
SRG
