Geometry traits to attribute
  • Sep 21, 2018 8:39 AM UTC
  • 10 replies
  • 265 views
lukas108
Forum|alt.badge.img+7
Hello, I have AIXM 5 reader in my workspace. When I load geometry, I got 2D points. I need to get elevation from geometry trait. My problem is that the geometry property extractor does not offer me any traits for export. Where can be a mistake?
Here is my data in Data Inspector:
Best answer by oscard
In this answer they comment about using Deaggregator and then the GeometryPropertyExtractor.
https://knowledge.safe.com/questions/61884/how-to-convert-obj-group-and-and-object-traits-to.html
Not sure if it could work for you.
  • Sep 21, 2018 8:54 AM UTC
How have you set parameters in the GeometryPropertyExtractor?
oscard
Forum|alt.badge.img+23
  • Sep 21, 2018 8:56 AM UTC
  • Sep 21, 2018 9:17 AM UTC
Does every point surely have the trait called "elevation"? I'm afraid that the trait is missing in some features.
lukas108
  • Sep 21, 2018 10:41 AM UTC
Thanks. Deaggregator helps me
lukas108
  • Sep 21, 2018 10:45 AM UTC
Good note. I did not think so. Next time I check it in advance. This time is the elevation property everywhere.
  • Sep 21, 2018 10:57 AM UTC
hmm, sounds strange. By the default Geometry XQuery, the GeometryPropertyExtractor should extract the specified trait without de-aggregating, if every geometry has the trait...
lukas108
  • Sep 21, 2018 11:08 AM UTC
It is quite strange. In GeometryPropertyExtractor is still any traits to choose, but I have elevation in attributes after translation.
  • Sep 21, 2018 11:31 AM UTC
These screenshots demonstrate how the transformer with the default Geometry XQuery works for aggregate geometries. In the sample data, 4 features didn't have "elevation" trait.
lukas108
  • Sep 21, 2018 12:11 PM UTC
I tried the same. I still can´t choose any trait to extract, but now it works without deaggregator. I think of some mistake in reader setting or in input data.
If you want test original data: obst1809.xml
  • Sep 22, 2018 4:28 AM UTC
I was able to extract the "elevation" trait from your sample data, without Deaggregator. I've not touch any parameter in the AIXM5 reader.
aixm5-geometrypropertyextractor.fmwt (FME 2018.1.0.2)
