GeoJSON format change
  • Aug 15, 2017 2:27 PM UTC
  • 62 views
Hello all,
I am interested in changed the output format of the entire GeoJSON document. I am converting an ESRI shapefile into a GeoJSON file and my output from that is unreadable in a platform i am using. Is there a way, manually if needed, to create a layout that the file will fit to?
  • Aug 15, 2017 2:54 PM UTC
Possibly the JSONTemplater might help you, but the specific way depends on what kind of format is required. Could you please elaborate the requirements for your desired format?
deanatsafe
  • Feb 8, 2018 11:29 PM UTC
Currently there is a problem with the GeoJSON writer when writing multiple feature types. The workaround for now is to use one feature type per dataset, or use dataset fanout. A more comprehensive solution is planned for 2018.1. For more info see: https://knowledge.safe.com/articles/40806/workarounds-to-known-issues-in-fme-20170.html
