Geodatabase_SDE reader issue in web service application
  • Feb 20, 2018 3:06 PM UTC
  • 71 views
I am using FME 2015 version.
I am developing a web service application to read data from ArcSDE database using 'GEODATABASE_SDE' reader. While reading the feature from the reader, it throws an exception as 'No definition was found for coordinate system 'ESRI(ESRI)'. The log file information is shown in the attached image:
But, I tested the same code in windows forms application and it is working fine. It finds the matching projection and read the data successfully. Its log file information is shown in the attached image:
Kindly clarify how to resolve this issue. Thanks
Sivakumar
pratap
Forum|alt.badge.img+12
  • Feb 22, 2018 5:20 AM UTC
Have you defined coordinate system?
Pratap
  • Feb 22, 2018 10:31 AM UTC
Pratap
Yes. The coordinate system is defined in the source data. If you see the second screenshot, the application finds the matching coordinate system 'DXX-DLTM'. It is correct.
But in the first screenshot, you can see that the application looks for 'ESRI(ESRI)' coordinate system. I don't know why it is looking for 'ESRI(ESRI)' system.
Note: First one is web service application and the second one is windows form application. But I used the same code in both applications.
Thanks
Sivakumar
pratap
  • Feb 22, 2018 12:02 PM UTC
Thanks
Sivakumar
Kindly refer the attached screenshot of defining the projection or it might be also a case where projecton is customized and not defined in FME coordinate file.
Hope this helps
Pratap
