Generating Tile Packages for use in AGOL
  • Apr 24, 2019 7:49 PM UTC
  • 389 views
I’m wondering if it is possible to use FME to generate tile sets/packages that I can then load to ArcGIS Online as a tile/map service? I’m looking for ways to cut down on those pesky AGOL credits and if I could use FME to generate them locally it sure would save a lot!
rahulsharma
Forum|alt.badge.img+12
Hi @bbbutler ,
Are you looking for a *.tpk or *.bundle reader writer that ArcGIS Pro products create?
If yes, there is a request to add this FME Desktop product as mentioned on IDEAS page here https://knowledge.safe.com/idea/64666/esri-compact-tile-cache-reader-tpk-bundlebundlx.html
Or you are simply looking to generate MapTiles which can be achieved using some transformer as TILER
Based on your question, I believe its the first options, which is currently not supported.
