Generate terrain from ASCI files
  • Mar 16, 2018 4:51 PM UTC
  • 156 views
Hi I have a set of .asc files. I am looking to use FME to generate a point cloud then build a Terrain in an ESRI's dataset from the asc files.
Is this something I can achieve using FME Desktop or do I have an ArcGIS 3D extension license.
jdh
Forum|alt.badge.img+41
  • Mar 16, 2018 5:21 PM UTC
You can use the pointCloudCombiner to turn your asc files into a point cloud and then write them out in a format like LAS.
You can use the SurfaceModeller to turn your points into a TIN or DEM, I don't believe FME writes Terrain Geodatabases directly, but I could be wrong about that.
Thanks for the suggestion. Would I be able to extract the height value at any given coordinate from a TIN or DEM?
jdh
  • Mar 16, 2018 5:28 PM UTC
The DEM (raster) will have the height value stored as the pixel value, the DEM (points) will be an evenly spaced grid of 3D points.
