Generate shapefile with no data
  • Jun 20, 2018 8:56 PM UTC
  • 103 views
Hi There, I am working on an issue where our FME workspace, reads data from a database and generates a shapefile. The issue that I am having is that if there are no new records, the shapefile doesn’t get generated but it keeps the last run that had any data. This is creating problem with next step of the process. I am trying to figure out a way so that FME generates a shapefile even if there is no new data (empty shapefile). Appreciate any help. Thanks Jay
fmelizard
Forum|alt.badge.img+22
  • Jun 20, 2018 9:21 PM UTC
Hi @jaygis Please see https://groups.google.com/forum/#!msg/fmetalk/Uza7HqgxF7Y/7tBapmyqMjAJ The solution is to create invalid geometry to send to the Shape writer if there are no other features.
davideagle
Forum|alt.badge.img+21
  • Jun 20, 2018 10:08 PM UTC
Perhaps in conjunction with Dan's suggestion you could use the NoFeaturesTester to create the dummy feature which will pop out with a Null geometry type.
  • Jun 25, 2018 4:14 PM UTC
Hi All, Thanks for some excellent feedback. I was able to implement a solution with combination of both the comments. Greatly appreciate your help. Thanks Jay
davideagle
  • Jun 25, 2018 4:18 PM UTC
Pleasure. Thanks for the feedback.
