From the Postgresql Writer, when a table is truncated and then inserted with new data is it possible to reset the Primary Key sequence to '1'? It currently restarts at the last PK value (+1) from previous entry.
fhyde
Forum|alt.badge.img+3
hkingsbury
Forum|alt.badge.img+56
  • August 2, 2021
it looks possible, before writing/truncating you could do something like the following
https://stackoverflow.com/questions/4678110/how-to-reset-sequence-in-postgres-and-fill-id-column-with-new-data
virtualcitymatt
Forum|alt.badge.img+39
Could you drop the table instead of truncating? I would think that should reset it to 1. Of course that might come with it's own set of headaches...
fhyde
  • August 3, 2021
Interesting option. I'll look in to that. Thanks.
fhyde
  • August 3, 2021
I could but there are going to be views associated to it so, as you said, "it's own set of headaches"...
fhyde
  • August 3, 2021
Worked perfectly.
