Format Text File where Column Names are Repeated on Each Row
tim.albert.vaa
Forum|alt.badge.img+9
I have a text file that looks like this:
"CommonCode":"EI","IATA":"EI","ICAO":"EIN","CarrierName":"Aer Lingus"
"CommonCode":"AM","IATA":"AM","ICAO":"AMX","CarrierName":"Aeromexico"
I want it to look like this:
CommonCode IATA ICAO CarrierName
EI EI EIN Aer Lingus
AM AM AMX Aeromexico
I want it to create the column names dynamically from the text file as the column names will change and increase or decrease in number.
In R there appears to be a command called:  “unsparsify”   Which according to this post seems to do it.https://datascience.stackexchange.com/questions/55879/file-format-where-column-names-are-repeated-on-each-row
I can do it using a combination of AttributeSplitters, ListExploders, ListIndexers, AttributePivoters and AttributeExposers.   But I can’t seem to get away from having to Explicitly input the Attribute names in the AttributeExposer and I need it to be dynamic.
Any ideas?
DanAtSafe
Forum|alt.badge.img+16
  • March 21, 2025
Hi Tim, Did you try a SchemaScanner? You don’t need to expose attributes for dynamic writing.
I got this written out to Excel:
Note that the fields are sorted alphabetically.
mark2atsafe
Forum|alt.badge.img+43
Nice ​@DanAtSafe - are you going to add this to the FME Hub as a new transformer?!
crutledge
Forum|alt.badge.img+27
  • March 21, 2025
I vote yes! This is an elegant solution. Something I will definitely use down the road (or run into and have to solve at that point :D)
