FME2013/2014 and oracle 12c
  • Apr 15, 2015 8:00 AM UTC
  • 11 views
I want to upgrade our Oracle 11g Database to 12c. Are there any Problems with FME 2013 while reading or writing 12c or is FME2013 full compatible with the latest Oracle version? Is an update to FME2014 nessessary? Has anybody experience with FME2013 and oracle 12c?
  • Apr 16, 2015 7:38 AM UTC
if this is crucial to your daily operations, I strongly recommend that you test this out on your system before making the jump. Having said that, your Oracle connectivity will mostly depend on having the proper Oracle client drivers installed, so make sure that you upgrade them as well.
I haven't tested the exact same combination of FME and Oracle, but I'd be surprised if there was a problem. But again, testing is the only way to know for sure :-)
David
