FME - "There is no geometry in this view"
  • Dec 17, 2018 10:00 AM UTC
  • 100 views
I have exported some buidlings in format CityGML from a different software. The format contains no semantics or attributes and I therefore want to continue to work with the file in FME.
When I view the file in Data Inspector I can see the buildings in 3D and I see that it is a IFMEBRepSolid. However when I try to work with the file in Workbench (e.g. transforming CityGML -> CityGML or try to run through GeometryValidator) I get message "There is no geometry in this view".
And clues to what can be wrong? I have attached a sample of the 3D-buildings. I am using FME version 2016.1. Thank you!
gio
Forum|alt.badge.img+15
  • Dec 17, 2018 1:49 PM UTC
@tornbladcarolin
I can just drag it to workbench and choose CityGml readertype (defaultsettings) and it works fine.
The feature type City Model contains no geometry but the featuretype Buildings do.
(I am using version 2018 002 though).
