fme_text features with empty fme_text_string. Could it be a GEODATABASE_FILE Reader configuration problem?
jorge_rosales
Forum|alt.badge.img+8
If you execute the attached workspace...
imageYou get fme_text features with empty fme_text_string (but TextString has a value).
imageAny suggestions?
Best answer by redgeographics
redgeographics wrote:
Let me rephrase my question: can you show a feature in ArcGIS that has a text string and then that same feature in FME where it does not have a text string?
I don't have ArcGIS, so I can't use the ESRI-version of the Geodatabase reader. However, if I use the OpenAPI Geodatabase reader I can see all points have a TextString attribute (which is not the same as fme_text_string).
So then a LabelPointReplacer to turn them into actual text objects does the trick.
Forum|alt.badge.img+50
Your screenshot shows at least one feature with an fme_text_string so it's probably not a configuration issue. Are you 100% sure all features should have a fme_text_string?
jorge_rosales
  • November 20, 2023
FME recognizes all features as fme_text, so according to the documentation I expected the fme_text_string, fme_text_size and fme_rotation attributes to have values.
jorge_rosales
  • November 20, 2023
Seems. If you open the gdb of the example in ArcGIS you will be able to see the texts. But if you read the annotations with FME, fme_text_string is missing.
  • November 20, 2023
jorge_rosales
  • November 20, 2023
Thanks @Hans van der Maarel​. The TextPropertyExtractor transformer seems to fix the problem as well.
