FME Server - WebService filename extension
  • Sep 18, 2018 5:52 AM UTC
  • 43 views
roberto
Hello,
I'm struggling with an integration problem.
I've published a workbench in FME server that must be called from an external application.
The standard URL of the published service is like this:
http://11.111.111.11:8080/fmedatastreaming/sample/FindAddressCandidates.fmw?param1=AAA &f;=json&maxLocations;=&searchExtent;=&category;=admin&POI;=fme123&outFields;=&forStorage;=&outSR;=
while the external application can only call the service using the following URL (without ".fmw" extension)
http://11.111.111.11:8080/fmedatastreaming/sample/FindAddressCandidates?param1=AAA
Is that possible?
Thanks in advance
Roberto
Best answer by hollyatsafe
Hi @roberto,
FME Server service requests are made as URL or form requests in the format below:
http://<host>/<service>/<repository>/<workspace>.fmw?<parameters>
The .fmw identifies that this is a workspace so it is not possible to alter the format of the request. I tested this using a sample workspace on FME Server and it will return a HTTP Status 404 – Not Found.
You can read more on the Data Streaming Service here: http://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/service_datastreaming.htm
  • Sep 18, 2018 4:19 PM UTC
Hi @roberto,
roberto
  • Sep 18, 2018 4:41 PM UTC
Hi @roberto,
Thanks @hollyatsafe.
I think so that the only option I have is to use IIS ARR or something like that.
Understandable.
Best regards
Roberto
