FME Server smallworld workbench error
  • Mar 27, 2018 9:11 AM UTC
  • 7 replies
  • 55 views
esaka
Participant
FME Server is not able to lunch the workbench which is able to work correctly via desktop.
If I select only one reader+writer that is able to work. However when I launch the whole reader-writer, than is getting error. I have attached the Smallworld-emacs error and the log file.
My goal is that I would like to download the whole data from SMALLWORLD to SL3/FFS any different database format daily via fme server schedules. I have prepared a workbench you can find below. 1 million records include.
lars_de_vries
Forum|alt.badge.img+10
Have you tried to restart the Smallworld FME service that is being called? I know this helped very often at a client I worked for in the past.
esaka
Participant
  • Participant
  • Mar 28, 2018 5:35 AM UTC
Thanks for your reply. after you said I have tried. However, I got same error ?t look like there might be more than one issue. To fix it, i have separated the layer which comes from smallworld.
What I couldn't understand that the dekstop is working fine, but the same workbanch on the fme server is not working.
lars_de_vries
Since you are running the workspace from FME Server, I am wondering whether the database connection is set correctly on the server and the permissions are set correctly?
esaka
Participant
  • Participant
  • Mar 28, 2018 7:59 AM UTC
Yes, database connection is correct. By the way, fme server is working fine the other workbench which configured with one layer. However If I try to run more than one layer, it is getting error like that
esaka
Participant
  • Participant
  • Mar 28, 2018 12:52 PM UTC
fme-server-sworld-error.zip
Now, I have restarted the fme server and tried only one layer which is pole.
1- running (ou can find the log file)
2-when it come almost 100.000 records and the log displaying 12page -5676 rows
3-job failed
esaka
Participant
  • Participant
  • Mar 28, 2018 2:36 PM UTC
Hi,I am trying the layers one by one, I have 5 layers1-wire (line)2-cable (line)3-Pole (point)4-Transformator(point)5-Substation(polygon)And than the wire has completed as expected.I mean to say pole layer is not running correctly
lars_de_vries
I think my knowledge of FME Server/Smallworld stops there.
The only solution I am thinking about is to use a WorkspaceRunner which uses an attribute that defines the different Smallworld tables to read and to use a workspace that kicks it off, possibly with the option to define which tables should be downloaded.
It is also possible to do it in a single workspace using multiple FeatureReaders. I would be carefull though, since each Smallworld reader needs to be closed before the next one can start (as far as I know).
