FME server read from filepath
  • Apr 26, 2019 2:06 PM UTC
  • 40 views
Hi, Im working on worspace that already has a subscription connected to a Topic Message. So when a new file is added to a specific folder, a Topic Message with the file path is sent as JSON. Depending on the name of the filepath I use a TestFilter to determine which test I want to do. This works!
However, after choosing the test, I want to retrieve the file and further test the data. As the filepath is knowned and stored, I tried using a FeatureReader to open it, but it doesn´t work... Does anyone have a suggestion on how this can be fixed?
  • Apr 26, 2019 2:23 PM UTC
