FME Server Polling IMAP
  • Nov 9, 2018 3:36 AM UTC
  • 79 views
cwarren
I have FME Server 2018.1 polling an IMAP account that is with Office 365 and I am only receiving the imap_publisher_content{0} in text/html. Is this a limitation to e-mail polling of IMAP? I really would like to receive the content in plain/text as well like before when I used FME Cloud's SMTP server. Any ideas? I've tried to use the html stripper and regex, but I'm getting mixed results with that.
Hi @madwarren,
FME Server should certainly be able to receive the content as text/plain as well. Have you checked that there is nothing else in the imap_publisher_content_type{} list. It may be being recorded in both types?
cwarren
  • Nov 10, 2018 9:38 PM UTC
Hi @madwarren,
@hollyatsafe, I've attached the incoming JSON from FME Server's topic monitoring and the imap_publisher_content{} and imap_publsiher_content_type{} lists only contains a single item. I wasn't sure if there was a setting I overlooked to be able to receive both text/plain and text/html. incoming.json
Hi @madwarren,
Unfortunately I have not been able to reproduce the issue you are seeing, polling Office 365 I am returned but html and plain text.
Is this the case with all incoming mail, or just ones from a particular server?
Please would you consider reporting this as a problem here so we can try out some more tests.
cwarren
  • Nov 13, 2018 12:41 AM UTC
Hi @madwarren,
@hollyatsafe, all e-mails are from the same e-mail domain that is used internally in our company. The e-mail address that is polled would only receive e-mails from other addresses from within the same @companyname.com domain.
I went ahead and reported using the link you provided to hopefully find a solution.
