FME Server (2012 SP 2) - Direct Workbenches to only run on a particular Engine
  • Nov 14, 2012 12:14 AM UTC
  • 60 views
G'day,
Is it possible to configure FME Server that only a certain Engine will run certain Workbenches and if so, what property within FME Workbench could be set for FME Server to detect?
Cheers,
  • Nov 14, 2012 6:40 AM UTC
Hi Goochy,
You can configure the Transformation Manager to run certain workbenches on a certain Engine.  See "fmeInstance" on page 372 of the Reference Manual.
Have fun :)
fmelizard
Forum|alt.badge.img+22
  • Nov 14, 2012 1:18 PM UTC
Oakey is quite right, although admittedly that has never been easy.  But yes you can include this fmeInstance parameter when you submit a job.
But I should mention that in FME Server 2013 this is going to much easier . You'll be able to associate a Repository with an FME Engine.
