fme-PostGIS-writer with PostgreSQL 10
  • Oct 26, 2017 3:00 PM UTC
  • 129 views
Moin.
I think there is a problem with the PostGIS-writer and the new PostgreSQL version 10. In PostgreSQL 9.6 there were no problems. Since I installed the version 10 of PostgreSQL (with PostGIS 2.4.1) the following error is thrown:
Error executing SQL command ('SELECT AddGeometryColumn('test', 'myTableName', 'geom', 3034, 'GEOMETRY', 2)'): 'ERROR:  Schema 'test' is not a valid schemaname
"test" is not the schema name, it is the database name. The schema isn't recognized in this command.
Matthias
Best answer by matze
Now i did the upgrate to FME build 17291. There is no more problem.
fmelizard
Forum|alt.badge.img+22
  • Oct 26, 2017 3:21 PM UTC
Hi @matze, when you upgraded did you change your database to an EnterpriseDB PostGIS database?
After the error message, do you see the following?
CONTEXT: SQL statement "SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7)
  • Nov 1, 2017 9:32 AM UTC
fmelizard
  • Nov 1, 2017 1:38 PM UTC
That's great to hear :)
