FME Ingesting AGOL json
  • Apr 14, 2025 3:37 PM UTC
  • 104 views
geckosolutions
Forum|alt.badge.img+4
Hi Everyone,
I have this “open” dataset provided by the City of Toronto.  I am using a few from the city that are provided in this manner.  The only way to bring it into ArcPro and then extract it to a geodatabase is to use the json address and add by url, then use the ‘feature to point’ geoprocessing tool to extract the data to points in gdb format, then use as needed.
I need to get this layer into FME from the live feed so I can analyze it and then push it out via other format(s), one of which is AGOL feature layer.
For some reason I have been unable to bring it into my FME script via any JSON reader or HTTP caller and I’m wondering if anyone else here will have more luck.
The link I am working with is as follows:
https://gis.toronto.ca/arcgis/rest/services/cot_geospatial2/MapServer/64
The json link is:
https://gis.toronto.ca/arcgis/rest/services/cot_geospatial2/MapServer/64?f=pjson
If anyone has the steps to bring the content into FME (geometry and attributes) to have it available for further analysis, that would be great.
I’m not good with JSON so I have to admin, that could be a large reason for this trouble.
Thanks,
nielsgerrits
Forum|alt.badge.img+67
The service is acting… special. But with a generic FeatureReader FME is able to read it.
  • Start FME Desktop.
  • Add a Creater transformer.
  • Connect a FeatureReader transformer.
  • Click ... Feature Types to Read and select “Road Restriction Point”.
  • Under Output Ports, select Single Output Port.
  • Close FeatureReader with FeatureCaching on.
  • Run workspace.
  • Attach AttributeExposer to Generic outputport and import, select from feature cache.
Sample workspace attached.
geckosolutions
Thanks for the help, I had an colleague working the problem as well and they came up with the same solution, but for some reason my system cannot connect via the script that works for them.  I have IT working on the issue to see if there is something there.  I am able to put the link in a browser and resolve the content/layers there just fine, but in FME feature reader it will not connect.
This is something I tried months ago and gave up quickly as I did not have time to troubleshoot, very frustrating to think it ‘should’ have worked and could have made my processes much simpler over the last few months.
