FME Exporter for Revit
  • Aug 1, 2017 5:23 PM UTC
  • 31 views
We are having problems with certain IFC Parameter data not being available. The IFC Exporter has been installed and all settings correct, but some shared parameters in Revit are not coming through into the FME Data Inspector. Is anyone having the same problem?
Hi @cfordigan,
May I please ask for a bit more information to better address your question? When you say "some shared parameters in Revit are not coming through", may I ask you to elaborate? What is missing from the output specifically? Would you be able to kindly share some sample data with us? This would be a huge help.
