FME Dynamic writer to geopackage with no geometry creates geom column in table
  • Jul 24, 2026 1:46 PM UTC
  • 127 views
arnovananrooij
Forum|alt.badge.img+5
I have a dynamic feuture writer which writes tables from my PostGreSQL/PostGIS database to a geopackage. Some of the source tables are with no geometry and some are with. This is why I have two readers, one for Posgresql and one for PostGIS. I write all the tables dynamicly to the geopackage with a FeatureWriter and have set the geometry type to read from schema definition. In the resulting geopackage I see the table which should not have a geometry with a geom attribute with all null values. The table gpkg_contents has a data_type features instead of attributes. When I try the same with a manual definition it works fine.
QGIS does not seem to have any problems with the geopackage that has the wrong definition, but ArcGIS Pro has. How can i get the dynamic writer to write correct to the geopackage? Or is this a bug or a works as designed?
I run FME 2023, but also tried it with FME 2025.
Thank you all
Best answer by desiree_at_safe
Thanks for opening a support case with us, ​@arnovananrooij! There’s an open case for our development team to dig into this issue.
We’ll update the community once that’s been resolved! Thank you for raising this 🙂
[Internal Note: FMEENGINE-99093]
j.botterill
Forum|alt.badge.img+69
  • Jul 27, 2026 12:17 AM UTC
So FME appears to be resolving the destination schema as a spatial table definition even when the incoming PostgreSQL table has no geometry.
Just before the FeatureWriter, inspect the ‘Schema’ feature in feature/record information... expose:
fme_geometry{}
fme_schema_handling
fme_schema_feature_type
and any writer-related schema attributes such as geopackage_type = ??
Does seem like a bug where dynamic schema generation is not propagating the equivalent of none geopackage. Perhaps raise this to safe support refereencing this article
arnovananrooij
fme_geometry{}
fme_schema_handling
To me it looks all good
arnovananrooij
fme_geometry{}
fme_schema_handling
desiree_at_safe
Forum|alt.badge.img+24
