FME Desktop won't load data from this WFS service.
  • Feb 26, 2016 10:22 AM UTC
  • 142 views
Forum|alt.badge.img+4
Would be grateful for some advice on this. FME is refusing to load any data from this WFS service. I can see the set of layers (get capabilities) from the service when I try to add the reader but when I select the data layer I need and hit ok the log is giving me the error below.
This WFS service loads vectors just fine into Qgis but not FME. Any help would be appreciated.
http://www2.guildford.gov.uk/ishare5.2.web/getows....
The top-level type definition referred to by the 'type' attribute in the element declaration is missing from the XML Schema
QName: 'ms:ogc_fid' | namespace uri:'http://mapserver.gis.umn.edu/mapserver'
QName: 'Integer' | namespace uri:'http://www.w3.org/2001/XMLSchema'
<element xmlns="http://www.w3.org/2001/XMLSchema" name="ogc_fid" type="Integer"/>
Best answer by geosander
Hi James,
I tried your URL in FME 2016 with these settings:
It worked for me..
The trick is to set "Ignore Application Schema" to "Yes". Might not be the proper way, but I did receive features from the WFS like that.
geosander
Forum|alt.badge.img+7
  • Feb 26, 2016 11:43 AM UTC
Hi James,
It worked for me..
Hi James,
It worked for me..
Brilliant....works fine for me too! Thanks for taking the time to investigate.
regards
James
geosander
  • Feb 26, 2016 4:36 PM UTC
regards
James
No problem! :)
What still puzzles me is if FME has problems reading this application schema for some reason, or that QGIS just is more lenient (and ignores the application schema automatically if it fails validation, for instance).
fmelizard
Forum|alt.badge.img+22
  • Feb 27, 2016 6:33 AM UTC
No problem! :)
I don't know firsthand but have overheard that QGIS generally ignores the application schema and hence is much more forgiving than we traditionally were. So we added the ignore option for cases like this. Glad it was helpful here.
